Most name brand oil does does put the basic spec info on the container. Now it is up to us to look these specs details up and to match to our engine requirements. In my case the Moly is use to fill in gaps on bearing surfaces and scoring on the cylinder walls. But considering that engine has 330K miles on it there bound to have been some wear even with the best oils if used.
I personally don't it previous history but I do know some idiot or (deleted text) RTVed the intake manifold and didn't wait for it to cure properly before adding the antifreeze. I finally got it stopped for a little while using an aluminum stop leak. Just got to get time to pull the intake and do the job right.
