I am sorry gentlemen but it is impossible to make a zero turn without locking one wheel, and when you lock one wheel, on turf, you will damage the grass, and if you don't like my comments on Exmark don't read them. :cool2:
YEP Robert you are right the problem is the rest of the people in the world is wrong.I am sorry gentlemen but it is impossible to make a zero turn without locking one wheel, and when you lock one wheel, on turf, you will damage the grass, and if you don't like my comments on Exmark don't read them. :cool2:
KennyV said:robert There are tens of thousands using ZTR's every wk. With no damage to the grass...
You have actually came across the problem that you were having...
If you need to make an actual Zero turn... Then that's what you want to do... You Do Not want to pivot a turn. A pivot is NOT a zero turn...
To Zero turn left, you Reverse the left drive while rolling the right drive forward. The machine will rotate on it's width... with Less disturbance than any sharp turn on a regular tractor... & you had the perfect spot to practice these type of turns, on concrete where you will see the difference...
It will take a bit of practice to become proficient with a ztr... but the incredible maneuverability in a zero turn is why it is worth the small effort to learn the system...
And like Bart said you have to have both Drive wheels turning when ever you are making a change in direction, this will become a natural adjustment in the controls as you use them...
Your body is also a ztr... if you make all your turns by pivoting on a planted foot, you'll have the same problems, especially if you are wearing shoes with great traction, like golf shoes... you have to learn how to turn whenever you try something different...
The only time I ever do a true pivot turn is with an Ag tractor when doing row crop work... That is at the end of run where I want to turn 180 degrees and offset the width of the tractor.... That is NOT a Zero turn...
Like anything worthwhile there is a bit of a learning curve, You have to regulate the rotational speeds of the two drive wheels in order to vary the direction your traveling, anytime you stop one, and leave the other moving, you will pivot your turn...
When your mowing, A true zero turn is rarely needed.. but when it is , you can not substitute a pivot... :smile:KennyV
Ken, what you and others are saying is that tight turns can be made without much turf damage, which is true,
