Need your help, which one to buy: JD Z245 or TORO SS5060
txzrider
  • / Need your help, which one to buy: JD Z245 or TORO SS5060
So now I understand about Robert... WOW!
toolfool
Robert just because you can not turn a ZTR without making divots does not mean others can not.
The real problem is with the operator not the machine.
That may be one of the advantages of a tractor is very little skill involved in operating it.
Other than requiring a small degree of skill to operate it the ZTR is a much better mower for cutting grass now for other uses the tractor has some advantages and that is why I have both types.
I have been mowing with a ZTR for 25 years and have not had all those problems that you had in the few weeks that you mowed with one.
Agree! If you are ripping your lawn on turns, you are not providing the proper speed to the rear wheels. The inside wheel needs to turn at the correct slow speed while the outside wheel turns at a faster speed. variations between the two will change the radius of the turn. If the inside wheel is to slow it can rip the grass in tight turns. The inside wheel has to turn, but this will also mean that you need to turn the outside wheel even faster to keep the desired radius. Its possible to even cause the inside wheel to run backwards when turning, which will really dig up the lawn! Just need to take it nice and slow to find the right combination of speeds needed for each wheel. The goal is to keep the rear axle perpendicular to the object you are cutting around.
djdicetn
Hello,
I am looking to buy a new zero turn lawn mower and there is two model who intereste me. I never owned one before.
I need your help to make the best purchase.
Which one would you recommend between John Deere and Toro ?
John Deere Z245 48"
- 23HP Briggs & Stratton
- 2-years/120 hours Limited Warranty
OR
TORO SS5060 50"
- 24HP Kawasaki V-Twin
- 3-years warranty
Thanks for your help.
I cannot seem to find a "Z245" on the John Deere website. I find a Z425 or Z445 with 48" decks. If you want a heavy duty residential ZTR I recommend that you take a look at the Gravely ZT HD. Below is a link to my local dealer showing the models in that series, their specs and their pricing if you care to take a look:
Runtime Error
