RickS said:Well, I gave him the $100, I rebuilt the Carb, and it is running fine, I put brand new blades on it and since it has been so hot here in Michigan, the grass has not grown, so I cannot test how the mower works.
Is there and adjustment to the position of the Engage lever so that I don't havve to pull it back while starting the engine?
reddragon said:YOU CAN REPLACE THE BEARINGS....BUT I DONT THINK YOU CAN GREASE PACK THEM...is that what you meant?
Why you yelling at him? LOL
Sent from my iPhone using LMF
That's OK Carscw, I can take it. LOL
I have been working on this thing and I had to order 2 new light sockets and I also had ordered a new lense for the front of it, They sent me a whole new grill, because the lense is no longer available.
I think that the contrast makes it look great.
Does anyone know approximatley how much my Lawn tractor weighs?
I have not got the means to get it weighed. I am trying to get some ramps to load it into the bed of a pickup.
Thanks a lot, then I can get the 1000 lb ramps and they would work fine.
:laughing:Nope not at all near that weight milestone :laughing: But I am sure that the 1000 lb steel ramps from Harbor Frieght will do the job.
do you have the model/serial number?...its usually under the seat....with that you can get a diagram fairly easy
Daniel
1999 MTD YardMachine 42" Deck
I have an 2001 MTD Yardman Yardbug with the B&S 9 HP engine. I bought mine for $200 this winter. It was very clean inside and out. Looked brand new. Even the plastic seat was perfect. The previous owner had an engine oil leak fixed. But I had to adjust and tighten up the steering, lube all pivot points, adjust the cables and sharpen the blade. At the end of this year I am sure the belts will need replacing.
The previous owner always used the under seat bagger, so I had to spend another $50.00 to buy the side chute and mulch plug off e-bay.
My yard is about half an acre. I bought a used rider instead of self propelled mainly because riding is more fun!
Very maneuverable design - gets around objects well. Tight turning radius.
Flexible design - Under seat bagger means no bulky side/rear bag attachment (this adds to the maneuverability factor).
When bagging, this mower can go right up to objects on both sides.
Powerful enough to go straight up the steep slope part of the lawn.
Flexible bagger also has side discharge and mulching attachments.
Fast enough for a moderate size lawn.
Funny looks from neighbors
Dislikes:
Side discharge may clog in damp long grass (duh).
Weak brake
Harder to get to cables and maintenance parts because of enclosed design.
Funny looks from neighbors!
I have a 2009 yardman 12.5 hp. 1st mower I ever bought new, and don't want to get rid of it just yet. Thanks for this Forum, looks like just what I need.
Hi all:
2007 MTD-Yard Man 21-inch pusher
Stens OE replacement blade
E3.22 spark plug
G-Oil 10w-30 "4 Cycle" oil
Thinking about picking up a Gator blade for the fall leaf mulching.
Greetings All,,, name is Gary. living in Albany, NY.. I bought an older MTD 136m667f118 with hopes of fixing tit up for the son. The son just moved to Cortland and now has to mow 2 acres. I replaced all the belts, cleaned the carb and adjusted the valves,,, Starts first time every time. I also repainted it, being the type that can not leave anything alone. I am new to forums.so some of the terminology is foreign,,, (trackback and posting avatars). So I'm just here saying HI!!
:welcome: Welcome! An avatar is like a profile picture. It appears right by your username. :smile:
It seem a lot of members do not use the avatars,, are they difficult to include??
No, they are very easy. You can add one here: http://www.lawnmowerforum.com/profile.php?do=editavatar :smile:
Where should the second part of my question be placed???. New thread or will you place it in the best area, and how will I know if there are any responces??
You could create a thread in the Small Engine & Mower Repair Forum stating the problem. You will know when you get responses because it will show an unread subscribed thread in the Control Panel above, and you should also get an alert to your email. But the best way would probably to just check up on the thread once and awhile.
Greetings from northern N.H. Got 2 mowers, a White FST-16 I picked up used a couple months ago, and a "Frankenstein" push mower...housing from a mower I found on the side of the road with a "free" sign on it, motor died a couple years ago, replaced with one from a mower I scavenged from the dump.
Love the 4 wheel steering on the White, though it did take a little getting used to. I do have a brake issue with it, I'll ask that in a separate post.
GREETINGS to all MTD mower owners! :thumbsup:
If you're new to the forum, please reply to this thread and introduce yourself and your mower (that is, if your mower have a name :laughing. maybe attach a photo or two of your mower and show off your pride and joy.
Also, if you haven't done so already you can upload a user avatar (picture under your user name). You can do so by clicking on settings and "edit avatar" or just click here.
Please be helpful and friendly to all other MTD owners (how could you not, right?) and if you like this forum, tell your friends about it. :biggrin:
We want to make this the best resource for MTD mower owners, and to do that we need your help! Questions? Experiences? Stories? Data? Photos? Articles? Links? Cool MTD stuff? Post it here!
Last but not least, please let me know if you have any suggestions for the site. We'd love to hear them.
Hi My Name is Matt and I Have a MTD Classic (Itç´ the MTD 50 year anniversary one) I use the mower in my lawn business (Matts Lawns) Thanks Matt
Hello, just joined the forum after purchasing a used 1998 MTD YardMan Yard Bug. Bought it after seeing it and hearing the engine run. Sounded great so I bought it after I was told it was recently used. Got it home last night and now the fun begins. Starts up like clock work but won't stay in gear. I'll be posting my experience as I work to bring it back to life. Stones
I have the same year yard bug. I took the deck off and let the grand kids ride it.
Not staying in gear could be a cable adjustment or the foreword reverse lever is loose
Hello everyone and thanks Muhammad this is a great forum! I have a Mtd lawn tractor with a 46 inch deck and a 21 horse v twin Briggs and a lot to learn about mowers so I think I have come to the right place!
I am afraid I introduced myself and my riding mower starting a new thread instead of answering this one I had not noticed. Sorry.
Anyway, having read a few threads, I'm sure I will find here all the help I could need using and servicing and, why not, modifying my "Trattorino" ("Little Tractor") as I call it.
Thank you and all forumites.
From my side I shall post some attachments I made and plan to make in future, in case they can be of any use to others with same needs as I have.
Let's go mowing: in this time of year growing grass does not wait for us!
Regards to all
Sandro
Hi I'm Dan.
Bought a house with a couple acres and it came with a 2003 (MTD) YardWorks riding mower. YardWorks is a Canadian brand of MTD. Its got a 42in deck 7 speed Shift on The Go trans, and a 17hp Briggs and Stratton Intek. It starts and runs fine, but its slower than a turtle hauling a cinder block. MTD hasn't been any help because the model seems to be exclusive to Canada. I contacted MTD Canada who were kind enough to give me some part numbers for belts. Took those part numbers to the local dealer, and they weren't even close. The Canadian model number is 13DD678G515. I should probably post this in another thread, rather than an intro. Sorry about that.
Hi, I'm new here from Ontario, Canada. I bought a early 70's White gt-1600. I believe it is the same machine as a mtd-960, gear drive. It would run if jump started when I got it. After getting a wiring diagram because every wire had been spliced i tried to change the ignition switch. I couldn't source the correct switch and I admit I didn't fully understand that the wire going to the engine ignition was for. For some reason I guessed the engine needed 12volts to power the ignition.
Long story short, I put 12 volts to the condenser from igniton terminal on a universal key switch. I noticed the magic electrical smoke when the key was put in the 'run' position. Can anyone tell me if i fried just the condenser or did I fry the coil as well.
Thanks
Check the engine mounting bolts for tightnessI inherited an MTD TurfPower 42" lawn tractor with about a 12 h.p. Briggs engine. I try to keep it running in memor of my dad. It uses a little oil and had been running o.k., but now when I shut it off, it makes a clanging sound and it wheezes when it stops. I'm guessing it could be something with the valves. Any ideas?
