Magneto ground wire
you are looking for ground where there should not be on so the clip goes on the battery + and you probe the wires
If the lamp lights up that is a fail if it stays out that is a pass
I did a little probing,l replaced the solenoid just in case and l was probing the wire from magneto and disconnected from ground on side of engine and it lighted up along with the wires that connected from ignition switch,safety switch module,and Magento.Are those suppose to be lighted.still only hear magneto click and no starter.l am fixing to retest the starter.lf it turns from jumping it and it turns , what should I check next.
Most of the time, maybe not yours, is the starter solenoid. It is the contact for the main amperage to turn the starter/engine over. It takes all the heat and such. When you replace a starter, you should replace the starter solenoid. Again his might not be your issue. Just talking out loud.
I replaced the solenoid,is there a part inside the starter l can replace.
looks like it has a fuse and an INTERLOCK MODULE, Briggs 7028606YP If all the other switches check out I would suspect the interlock module. Not sure how to or if you can check it.
