Magneto ground wire
hlw49
What kind of test light are you using? Is it a light with a battery or one where you have to have current from the wiring on the engine?
navydad2022
One l that have to connect to battery pos or neg,
navydad2022
So sorry for your loss.
Thank you, l'm just lost with this mower ,l put a new solenoid just for piece of mind.But now my mower clicks and no action on starter.l guess with my loss and this going on is getting to me.
hlw49
That can happen. Will keep you and yours in our prayers.
Looks like this is yet to be resolved
So we might start again
If you read the snapper model number correctly then the wiring diagram should be as under
So when you turn the key to start battery power should go from the S terminal on the switch via the blue wire to trigger the solenoid
Because electricity has to make a full loop the solenoid trigger makes a ground contact to the frame.
When this happens the solenoid connects the heavy red & black cables on the solenoid to send high current to the starter to turn it .
Normally that blue wire would go through a couple of switches to prevent the engine cranking if the blades are engaged , brake is not on, drive is not in neutral.
But according to this diagram, it is a direct connection
Taking a step back the battery power to the B terminal on the key switch comes from the battery via the solenoid, through a fuse.
A common mistake is to put the mower power feed on the switched terminal on the solenoid ( the heavy cable that goes to the starter motor )
So for a no crank situation you need to check for voltage from the battery + to the solenoid , to the fuse, to the B terminal to the S terminal ( when key is in start position ) to the trigger terminal ( blue wire ) on the solenoid .
To double check the solenoid run a jumper from the red CABLE to the terminal the blue wire is on
Engine should crank
If not check the body of the solenoid is ground
Now for the fun bit, the no start
The black (ignition ground =kill ) wire can go to ground 3 ways
1) direct connection to ground via the key switch ( M + G )
The following assumes the T shaped outlines are supposed to be wire plugs
2) via the seat switch and pedal switch.
Note if the plug on the seat switch is disconnected or not fully connected that counts as no one in the seat
3) via the PTO switch Pedal switch & module ( can't really see what the module does unless it also turns the blades off .
navydad2022
Engine should crank
Thank you, I'll give it a try and get back with you.l bought a new solenoid just in case and put it on.battery is new and next changing switch for piece of mind 🙏
navydad2022
Engine should crank
I solved the mystery on this issue finally .it was blade engagement switch that was acting up and replaced it.Now it's good, tried it out and no issues.But l have another one that was using and it reviving up high all of a sudden.could be the governor inside gone bad.thank you for helping me on Snapper.
