Clutch is getting Worn, more distance between Plates equals more Current when engaged. Very similar to A/C clutch on a vehicle. Replace or Adjust. Could be Dirt or Debris in clutch. Blow it out with compressed air. Some Electric clutches have shims(washers) you can remove to compensate for wear. Good Luck!
