Cool-Ace
- Aug 30, 2019
- 7
- 44
Hi to all the mower Mec's, I have a Husqvarna LGT2654 that the PTO switch keeps going bad. I think I have replaced it 3 times and now need another. I am not sure why it is going bad but you know the fuse that is on the wiring harness it had a 30 or 35 in it when it went out the 1st time so I reduced it to a 25 then this last time to a 20 but the fuse still melts down. It has me wondering if the PTO it self might be making it get hot because it is bad? I can replace the switch and fuse and runs fine for a while before going out. If anyone has any idea what the main problem might be please let me know. Wires on PTO are good and as best I can tell the PTO is OK but I could be wrong.
