EngineMan
- Jun 12, 2012
- 9
- 2,275
You should not be able to see the spring under the pulley, and you say that its very tight when you try and put it back on, it shouldn't be tight, so you have two options replace the cover, or take the starter assembly apart.
If you have never taken one apart, take you're time and remember what you do (very important).
1 pull the rope out of handle to be able to undo or cut the knot.
2 bend back one of the two tangs (parts that are over the white pulley) (only one) GRASPING THE PULLER WHICH IS WOUND TIGHT and lift out and remove from the cover, disconnecting spring, remembering where the ends of the spring go's.
3 look for any damage or anything that looks out of place and then clean the spring.
INSTALL SPRING
place a dab of grease on pulley (the side that the spring go's) set pulley into housing and bend bumper tang down. Place a 3/4" square piece of stock into center of pulley hub, GRASPING STOCK WITH A WRENCH WIND PULLEY UNTIL SPRING IS WOUND TIGHT. Then back off pulley one turn until hole in pulley for rope knot and eyelet in blower housing are in alignment.
Spring should be securely locked in smaller portion of tapered hole.
Install rope.
I have done this many times over the years, but if you have never done so I would tell you to take it to someone who has, he will know what to look for and also what to do.
INSTALL SPRING
Install rope.
