PTmowerMech
- Apr 16, 2018
- 427
- 3,256
So I did the same thing last night, as the night before. Woke up this morning to the battery level still on zero. UGH!!!!!!!!
Are you sure it is a battery problem and not a charger problem. I am constantly needing to wiggle the charger to computer connector on my HP because it likes to loose contact and stop charging.
Does it say it's charging? I'm with ILENGINE thinking it may be a charger problem. It's a common issue for the solder connections on the charging port to break on laptops due to using on your lap while charging and stressing the charger port connections, tripping on the cord etc. Unfortunately you usually have to deconstruct the computer to access it.
Ive never heard that before, if its a lithium battery i wouldnt discharge it completely, can actually cause wear in the long runUPDATE New battery, after letting it die completely, per the instructions, is once again stuck at 6%. Surely I didn't get two bad batteries.
So is it showing yellow when charging? If not your port is bad.When I move the charging connection or the cord, the charging light by the connection doesn't change. When it's charging it's yellow. When it's plugged in, with low battery, it blinks white.
But the light doesn't change when I move the cord.
