cpurvis
Don't pull a line completely off an injector. CRACK open the line at one injector (not the injection pump) slightly, maybe 1/2 to 3/4 of a turn. Keep the two wrenches on or a close to the injector as you can. Crank the engine until you see fuel begin to leak our of the fitting on the injector. The engine may start to 'hit', running on that cylinder. Tighten the nut on the injector as soon as you see fuel or the engine starts to run. Repeat this process on another cylinder. It will probably start and run now, but rough. Speed the engine up and the last injector will probably bleed itself. If not, bleed the 3rd injector.
FWIW, all old mechanical injected diesels start with the 'rack' in the fully open position. It makes no difference where you set the throttle, the engine will be receiving fuel at the maximum rate when cranking. You can hear the engine rev when it starts until the governor pulls the rack back to idle.
