7394
- Sep 5, 2014
- Threads
- 90
- 5,133
He only stated, if modified in any way other than by a Licensed Dealer, (cause they make $0.) it is considered tampering with the emissions. Which is BS. But they will sell the foam pre-filter. And instead of a sock, I used to use womens sheer stockings, cut to fit.Did he explain what adverse consequences a better air cleaning system was going to cause?
Wouldn't adding a sock to the oval FR filter be a similar crime against the environment? Can I expect a visit from the Environment Police Agency soon?
Used to be you could chose which air filter system you wanted on Kaws & they would install on your new machine. A Tech @ Kawasaki® told me this.
I was1/2 tempted to simply swap blower housings. But they each have a Serial number. So that won't fly. & I likely will sell the Toro, as it seems Dealers are having trouble getting new machines. And I really do not need 2.
