Where is the tag located to tell what the modle is of a Craftsman lawn tractor?
I have one that is gray, 16 hp.
Answer:Where is model number on craftsman lawn tractor?
Most Craftsmans made since the early 1990's have a sticker on the top of the mower under the seat.
Yes, a picture would be very helpful, but I might know the answer without one. On WikiAnswers I found this:
Question:
Answer:
(Where is model number on craftsman lawn tractor)
***I would check there first, and if it is not there then I would post a picture for us. :smile:
and if its not there then there is a sticker with parts on the engine cover. mine has the model numbers
It has 5 speed 44" 16 hp and a II is on the hood.......
It is the kind with the square looking hood verses the newer aerodynamic looking one. I did not get a pic today and I did look under the seat earlier and did not see anything.
try to use Manual :smile:
I just bought it recently used and there is no manual. If I knew what the modle was I might could fine one on the net to download.
