Identify modle of Craftsman Tractor mower
jekjr
Where is the tag located to tell what the modle is of a Craftsman lawn tractor?
I have one that is gray, 16 hp.
Yes, a picture would be very helpful, but I might know the answer without one. On WikiAnswers I found this:
Question:
Where is model number on craftsman lawn tractor?
Answer:
Most Craftsmans made since the early 1990's have a sticker on the top of the mower under the seat.
(Where is model number on craftsman lawn tractor)
***I would check there first, and if it is not there then I would post a picture for us. :smile:
and if its not there then there is a sticker with parts on the engine cover. mine has the model numbers
It has 5 speed 44" 16 hp and a II is on the hood.......
It is the kind with the square looking hood verses the newer aerodynamic looking one. I did not get a pic today and I did look under the seat earlier and did not see anything.
on the inside of the hood. should have part model numbers and the model number of your tractor.
Hi
On a craftsman mower the model number is under the seat and to fine a mananul for your model try going to www. managemylife.com and you should find your model for a book:licking::licking:
