The bad news, the idle is kinda higher than expected and once you crack the throttle opne a hair bit more, the engine wants to rev itself to death.
Out of curiosity, I turned the airscrew all the way in while it was idling, this shoulda killed it but it kept running.
Have you felt resistance on the governor arm with the engine running... Is the governor actually working?
Have you taken the screw and it's seat completely out to check if the point is damaged?
You can easily swap engines but this one needs to be figured out... too strange. :smile:KennyV
