I made some progress today, kinda having what you have in mind Briggs, I starred and starred some more at the linkage and I finally realized, someone had bent the linkage stop back, not giving it full travel, so slow was more like part to mid throttle.
So the good news, the throttle linkage is squared away, and it will idle reasonably low.
The bad news, the idle is kinda higher than expected and once you crack the throttle open to a hair below part throttle, the engine wants to rev itself to death. So and fast speeds are accomplished with about 1/2" movement of the throttle lever, as opposed to the 2" potential travel of the speed lever.
Out of curiosity, I turned the airscrew all the way in while it was idling, this shoulda killed it but it kept running.
This makes me think air leak somewhere, so the best I know to do right now, is to start over, Im gonna tear the carb apart, clean, soak, blow air, perform ritual dances and give it the royal treatment and replace every thing thats not made of metal between the cylinder head and airfilter. :biggrin
Sound good?
And just so Im 100% sure, if the throttle lever is set to the fastest speed, the carb butterfly should be fully open or no? Im thinking no, as I believe the governor is meant to increase the engine speed by opening the throttle, if the engine is put under load, say cutting tall grass all of a sudden, so Im thinking if the throttle is open all the way under the fast lever setting, then the governor cant open the throttle any more? Thoughts?
Have another question, just a general mower question, the mower I have been using, has a 18 hp briggs v-twin engine, any chance the 12.5 and 18hp would use the same mounting points/drive gears? Cause I wouldnt be opposed to doing an engine swap. :biggrin: Funny thing is, the neighbor on the other side of me give that mower to me, he thought the transaxle was fried, but I replaced some belts and have been using it ever since, its an old one but it runs pretty good.
