Well fellas
Figured Id post what I learned, maybe someone one day can use the info to save theirself 35 bucks. :biggrin:
Earlier I mentioned the plastic shaft that holds the choke butterfly, melted. I got to looking at it, remembered someone give me a couple weedeaters, yeah I know, sounds odd. I remembered the choke and throttle shaft on the weedeaters were fairly long, considering the ports themselves are not big at all.
Long short, if you have the choke butterfly off the lawn mower carb, you can use the brass throttle shaft off the weedeater and the spring off the weedeater choke shaft, combined with a hacksaw, drill bit and about five minutes, to make what will appear to be an OE product. :biggrin:
