Hustler Belt part #791988
Stens part #265-336
Rotary part #15190
5/8” x 140.77 (140 & 49/64”)
Stens part #265-336
Rotary part #15190
1: Hustler belt part #What are the three parts after the belt part? My lawn is getting to rain forest level.
Are stens and rotary other parts or other brands or what? I purchased the hustler belt and am not having luck getting it working correctly.1: Hustler belt part #
2: Stens belt part #
3: Rotary belt part #
4: Actual belt dimensions
Stens and Rotary are aftermarket parts dealers, manufacturers, distributors.Are stens and rotary other parts or other brands or what? I purchased the hustler belt and am not having luck getting it working correctly.
791988Stens and Rotary are aftermarket parts dealers, manufacturers, distributors.
You need to confirm the dimensions of your new belt.
Also, give us the numbers off of the new belt. You could have the wrong belt.
If the belt is correct and you are still having problems, take it to your local Hustler or Big Dog dealer and have them figure it out.
This seems like a solid plan. I will do this asap.OK
Your electric clutch is gone to heaven
Confirm by removing the belt and watch the deck drive pulley while some one else cranks the engine
If the pulley turns with the PTO turned off then either the switch-wiring is bad or the PTO clutch itself is bad
Unplug the clutch and repeat test
Pulley still spins = dead clutch
Pulley does not spin = wiring problem
Let us know what you find
