shadetree#1
- Oct 31, 2022
- 153
Is this a type?
You typed "When you went to CHARGE things up it would not start"
??????????? What did you charge? Battery or ????
Next: If you are not seeing a slight dip on a rocker arm as the piston is almost at TDC as it's COMING UP ON THE COMPRESSION STROKE with the valves set at minimum specs (properly adjusted at 1/4 inch past TDC)
the ACR on the camshaft is not operating properly.
You say that you do not ever see a slight dip. You need to double check a look for this. Watch very closely at the rocker arms and if you do not see the slight dip on a rocker slightly opening a valve you are not going to get a Automatic Compression Release. Take the spark plug out and turn the engine slowly manually and you can also insert a dowel rod into the spark plug hole so you can tell when the piston is coming up ON THE COMPRESSION STROKE.
Make sure you are on the compression stroke when watching for a rocker arm to take a slight dip. The rocker arm should just briefly dip (this slightly opens a valve to reduce compression) just before TDC then come back up right at TDC and this dip and back up will take place within just a few degrees of flywheel rotation just BEFORE TDC. Watch both rocker arms. I think maybe that China engine ACR is on the exhaust rocker valve but I'm not sure.
The ACR is operated (disabled like you are seeing erratically now) by centrifugal force when the engine starts running and when the engine stops running, a little spring on the ACR mechanical mechanism on the camshaft resets the ACR for the next start. (to reduce start compression)
Summary: centrifugal force disables the ACR for engine run.
Spring return ACR when engine rpm's get below 500 or the engine stopped.
You can review this on-line.
