Nwatson99
- Jul 29, 2013
- 18
- 531
Re: Engin Oil
Exactly the same what I thought, when I cut one open right beside a Kawasaki filter and a Purolator Pure One. The Kawasaki and Purolator filters looked and felt much better and stronger, so that is why I only use the Kawasaki filter with my oil changes and found it is much cheaper to order 6 or more at one time.
Yes.
The filter material has cheap-*** cardboard ends, which are supposed to be metal. Cardboard can easily break apart, which can cause the filter pleats to move from it's fixed spot.
The filter media is cheaply built, with a low number of pleats put in it.
