- Nov 29, 2014
- Threads
- 64
- 24,702
Are you sure of that ?I use anti-seize on my blade bolts. A bit always gets on the bolt face next to the blade, and instead of over-tightening the bolt, it seems to slip a bit under it. I use a Ryobi 1/2 impact wrench rather than my air tools and never have a problem. There are two types of anti-seize available nowadays: aluminum or copper-based. I prefer the latter because of its ability to withstand heat when I use it on exhaust studs and bolts. Go sparingly... a little dab'll do ya!
Copper is generally used for all but very high temperatures and on stainless steel.
The silver is usually nickel for stainless and very high temperatures like exhaust manifold bolts .
