Craftsman 6.75HP push mower died
If you get a fuel squirt with your air compressor, then the primer bulb is defective. Or u have a gasket issue? Doesn't take a ton of air to squirt just saying. Imagine blowing into that carb hole with your mouth.
bluegirl
Hi all, I bit the bullet and replaced the primer bulb assembly and it fired right up. Couldn't really tell if it was warped, but it must have been just enough to make the seal incomplete. I never did replace the carb.
