- Nov 29, 2014
- 24,995
And the thickness of the sim is determined by closing up the motor, measuring the end float then placing the approppriate sized shim ( or shims ) on the crank then buttoning up the engine a second time.
I have been setting end floats on cranks that are perpendicular to the case joint since I was 12
Shim or no shim the gasket changes the end play .
