Briggs Leaking Oil
And the thickness of the sim is determined by closing up the motor, measuring the end float then placing the approppriate sized shim ( or shims ) on the crank then buttoning up the engine a second time.
I have been setting end floats on cranks that are perpendicular to the case joint since I was 12
Shim or no shim the gasket changes the end play .
Scrubcadet10
Moderator
Staff member
I did think it was odd briggs,from what I could see only sells a .012" shim.
It would be wise to use the original gasket
Mr-Mom
Thanks for the heads-up. I'll get a genuine gasket and look for the shims and make sure they are reassembled correctly.
Scrubcadet10
Moderator
Staff member
Should be only 1 shim on the crankshaft, just slides over the shaft and sits flush against the gear. Sometimes the camshaft will have a shim too.
Mr-Mom
I had some time this after noon, so I wend ahead and pulled the engine off the mower chassis. As warned - one of the three bolts broke. It was odd, the bolt was not seized but it would only turn a tiny bit. It was the one on the right side that you can see the tip of coming through the motor, and I could see that it was turning. I gave it lots of PB blaster and tried working it lose. I got it up to about 1/4 of a turn and then the head busted off. Fortunately, I was able to drill the bolt out pretty easily and a 3/8 bolt and nut will work fine as a substitute.
As for the gasket, it came apart when I split the cases, so it is hard to say if if was actually damaged and causing the leak. As the photos show, there is plenty of fresh oil right a the place where I see the worst evidence of a leak. I'll have a new gasket in a couple of days and I'll button it up and see how it does.
Ever heard of using UV dye to find the leaks before you tear things apart?
Scrubcadet10
Moderator
Staff member
You put dye in the oil and with a UV flashlight you use it to trace the leak. works great for cars and trucks too, i rarely use it for small engines though.
Mr-Mom
I'll remember that. It could be useful someday. As for this issue, the place where I think the leak originated from was not visible as it was right under the cylinder. I'll know the truth when I get the gasket, put the thing back together and run it. If it still leaks, I might just try the dye route!
tom3
Really a clean looking engine inside, shows good maintenance.
