I have a Craftsman walk behind mower with a Briggs model 128T05-5268-B1 engine. Recently the machine seemed to be using quite a lot of oil. It was working hard and was hot and a bit smokey. I checked the oil and it was off the stick. I topped it up and after ten minutes or so, it was smoking again. I checked the oil and it was low again and again I topped it up. This went on for a while and I decided to dig into the thing and see if I could find an obvious problem. I was unable to find anything obvious but looking around at the parts diagrams I noted the oil breather assembly and decided to have a look at it.
Once the engine was apart, there was no obvious problem with the oil breather but I tore the gasket getting the part off. A new gasket is $3 and the whole vent with a gasket is $7. I got a new vent assembly and installed it. I also replaced the spark plug, the air filter and I drained the oil and topped it up with the specified 18 ounces of straight 30 weigh oil.
I started and ran the machine. It ran OK with no more smoke than normal if I worked it hard. However, I noticed quite a bit of oil on the mower deck right under the oil vent. I checked the oil level and it actually seemed a bit high - I'm not confident that 18 ounces is the correct spec - I think 14 would be better. In any event, I checked the oil breather bolts and they took a bit of tightening and I ran the machine again. Once the machine was good and hot it started leaking again at the same place. I tore the machine down again and completely removed the oil breather. I checked the oil galleries, which were nice and clean. I did notice a bit of old gasket on the engine surface. I cleaned this off and then put Permatex FormAGasket on both sides of the gasket before reassembling and let the machine sit for two days before running it again.
My efforts made no difference. Once the engine was hot, it started dripping oil on the mower deck, right at the same place below the oil breather. There is no external orifice on the oil breather, so the oil is not coming from there. I'm quite confident the gasket is not leaking. The oil comes out around the bottom of the cylinder, but not at the head gasket. It comes out at the body of the motor. I have been assuming that the oil breather vents to the carburation system, but I don't know how. It is possible this just comes out of the engine on some vent I'm unaware of?
This only seems to happen when the engine is fully hot and working hard. An suggestions as to what is happening here?
Post Script:
Writing these things down always helps me think through them. I found a better parts diagram for this engine at https://www.m-and-d.com/pdfs/briggs/12U800-ms0989-0904.pdf and I noticed that there is an "oil breather passage", part number 697734. This appears to run under the motor and over to the carburetor side. I suspect this is leaking; possibly a bad gasket or just loose bolts. An suggestions on how to get at this component without removing the motor from mower chassis?
Post Script:
