Some manufactures require you to use their oil to maintain the warranty. They put specific dyes in their chemicals to ID them. Hmmmm. I'm 60+ years old and have never filled out a tool or appliance warranty card, so their warranty threat means nothing to me.Maybe it's best to use for example Fruit Loop oil in your Fruit Loop trimmer? Sticking with the manufacturers recommendation. Since they made the engine, they should know.
A lot of peeps become paranoid with 2 stroke oils . Actually any good FC rated oil will perform well in any air cooled engine . Similiar with the older TCW- 3 rated oil , that became a marine oil application . FD is only better for low smoke and high detergency , critical service applications in my opinion .I have been using the Super Tech (Walmart) brand in weed eater and blower engines for 25+ years. No issues ever. I used to use it (and Yamalube) in 250cc bikes back in the late 80's and 90s. No issues there either. I raced and did my own engine overhauls, so I have seen the pistons and cylinder walls back then. This oil is fine for 2-cycle engines.
