If you are a home owner, then I'd buy any good
synthetic 2-stroke oil from any named shop (Tractor Supply, Lowes, HD, Ace Hdwr, etc. ).
If you are a pro and you need the ultimate, then I would buy
Valvoline. Valvoline is a name you can trust. They don't do anything but make great oil. They are owned by the
Ashland Chemical Co. They don't make oil filters, wiper blades, or V-belts, they just make oil. There's no hype, just solid performance.
				When it comes to lubricating lawn mowers, chain saws, string trimmers, outboard engines, jet skis, motorcycles, scooters, portable generators and snow blowers, there’s one motor oil that does it all. Valvoline Multi-Purpose 2-Stroke Engine Oil is specially formulated for most high-revving, small...
					www.valvoline.com
Hope this helps.
