Bent tie rod
KennyV
:laughing:LOL...:laughing:
Ha ha... And with some Great humor this post ends. :rolleyes:
I would have 'Thought' the cold weather up in South Dakota would have given you a little thicker skin...
If you can't see the reason for the question, I don't know what to say... Because I was thinking the same thing Plus a bit more.
BTW if you ride/rode a Greeves:thumbsup: you should have Very thick skin...
:smile:KennyV
djdicetn
I think it's best if I just don't say anything more about your story.
Did not mean to hurt you feelings
And thank for your post now we know if we blow a fuse to look at the tie rod.
I hope you stick around as I feel you could help others with your knowledge.
(( cowboy up and get over it ))
Way to man up and apologize!!! Personally, there are times when your to the point "raw humor" is, in my opinion, an attempt to get the OP to step back and take a look at what he said and how he said it. Then again, sometimes a thin-skinned poster with a chip on his shoulder will pen an agressive rebuttal response and further incite a thread riot amongst us:0)
Carscw
Funny thing is I did not even read his whole reply until now. Guess he was upset.
I really am working at being nice.
I sell a lot of mowers on Facebook. Put a post up for selling a mower big long list of what has been done to it and the last thing I put was $500 obo and two guys asked how much.
Only thing I could think to say was. Put the beer down and put your shirt on then find someone to read all this to you. He gave me $450 for the mower.
YooperNC
I bought a used Husqvarna YTH 18542 earlier this year. After a few mowings, I noticed that the front wheels were toed out a bit too much. That's when I saw the bent tie rod. I tried straightening it using a bench vice, but it bent pretty quickly the next time I mowed. I ordered a new one and installed it (photo attached). It has been good ever since.
Now for my question: The tie rod sits very close to the clutch housing. It actually touches it. I have not had any blown fuses or any other issues, but it seems odd to me that it would be so close. Is this the way it is supposed to be? Or is there something else that might be out of alignment? I have attached photos of the tie rod in very close proximity to the clutch wheel, and the end of the rod attached to the left wheel. Does this look OK?
Question #2: When I turn sharply to the right, most times the steering locks there, and I have to fight to get it to release and go straight again. Can anyone help me understand why this might be happening? It happened with the bent tie rod, so I thought that replacing that would alleviate this problem, but it hasn't.
Thanks in advance for your time.
-- Dave
P.S. First post - please be gentle. :laughing:
reynoldston
It looks like your tie rod got hit hard to bend it that bad. Seeing that it got hit so hard its a possibility that your steering arms got bent upward. I would try to bend the steering arm down just a little.
YooperNC
Thanks, I'll look into that. If they can bend down slightly without compromising the steering, I'll be happy. Luckily, the new tie rod has held up for several mowings.
BlazNT
Are you sure the bar does not attach from underneath?
Problem comes from the fact the the mower was designed with a manual PTO when the electric clutch got shoved on things had to be worked around it.
The outside of the housing is grounded so tapping it with the tie rod will not cause any electrical problems.
A tie rod always goes through an arm square to the arm otherwise it will lift rather than push left right.
If you look at the angles at the end of your old rod compared to those of the replacement you will see the old ones are square on to the arms while the new ones are at an accute angle.
So that would indicate the original rod had a bend in it from new to clear the PTO clutch and the new rod requires the arm to be twisted which would lower the entire rod.
I would hazard a guess that newer models have a modified steering arm to take the strait tie rod as a bent tie rod is extreamly bad / lazy / cheap engineering and thus very commonly used on mowers.
You might like to consider moving the engine back 1/2" which is what the factory should have done in the first place but that requires making a new die to punch out the holes and that costs money.
YooperNC
I had that thought, but every break-away diagram of this mower shows it above. However, since it has a metal washer and a cotter pin, I suppose it could be attached below. Thanks for the suggestion.
YooperNC
Your answer makes perfect sense.
Not that I'm going to take this on, but wouldn't this change the length of the two belts that drive the rear wheels and the blades (by about an inch each)?
