About the steering system.
Bange
And speaking of bushings... I'm finishing replacing the steering shaft's upper bushing with a bearing...
Now just how you get be in a fix position? So far in 14 yrs I have only replaced two of those bushings. I have had more problems with the bottom end of the shaft.
Briggs 708257 > Husqvarna 532195228.
Probably a lot of trouble to replace a $2 bushing, $4 US Retail.
Bange
I don't know the past beyond 2 years, when I bought it, and I noticed a very annoying gap, which I decided to eliminate now... and with materials that I have available or recycled... zero gap, zero cost... for 50 years ahead.
m_20230702_115146.jpgm_20230702_111038.jpgm_20230702_111506.jpgm_20230702_120510.jpgm_20230702_131939.jpgm_20230702_132055.jpgm_20230702_151854.jpgm_20230702_165155.jpgm_20230702_165251.jpg
Bange
Another stage almost completed...
m_20230710_142148.jpgm_20230710_223123.jpgm_20230711_121626.jpgm_20230711_183705.jpgm_20230711_183658.jpg
But there's still a problem... it looks like this piece (#2) is crooked.
I'll take it out tomorrow and check it out...
Very rarely happens but part # 67 wear grooves in the and even the hole they sit in can get flogged out oval
The two plates which sandwich # 2 need to be adjusted so # 2 can pivot around the bushes # 67 but not rock as per your diagram or roll as this changes the steering geometry drastically .
The bushes # 67 are supposed to be oiled daily but most are never ever touched
This will be a hell of a good mower by the time you have finished I admire you perseverance
Forest#2
Yes, the sector gear to the fan gear is a wimpy area on lots of the lawn tractors and I've seen several that Bubba and jethro put in the WRONG SIZE plastic bushing. (and them plastic Chima bushings are a jaw dropper at their prices.
Bange
The balance movement is normal... there is a gap that I also consider normal... the problem is that stopped on the plane I can observe that the vertical axes of the wheels point slightly in opposite directions (front/rear), which leaves the wheels looking drunk.
I like mechanics, I have many tools and I see this as a hobby... but I don't know anyone who has this or any other similar machine to be able to compare or even talk about, I'm going by my logic... sometimes it works and other times I have to go back a step, but I hope that later on I will reap better results.
Pull # 2 out and check the bushes and the hole they run in
One of the two plates that # 2 sits between will have slots for the purpose of adjustment
Usually it is the front one
When you turn there isa very high bending moment at the pivot
Bange
I don't know if I understood what you wrote correctly, but the industry strives to do things to hold you to them and I don't like that... often there's no way.
