About the steering system.
Bange
There is a little play on the axles of the wheels, I saw some replacing the bushings with ball bearings... would anyone know how to tell me the number of such a bearing?
IF you are referring to Hus 532009040 wheel then yes there are several bearing options. Some are flange bushings and some are flange ball versions. There is even a roller bearing on the following list. They are for the 3/4 spindle and a wheel hub that is 1-3/8". You have google each part number to see which you are interested in.
Gord Baker
Your Rack is badly worn (sharp teeth) and you likely also need a new Sector Gear and Bushing.
Bange
Show! But in the video I saw, it wasn't a replacement kit... it was common bearings, which are much cheaper around here.
I'll take the measurements and see if there is direct replacement or needs adaptation.
As for the needle axials, I have a doubt if they are efficient for a long time, because as they are open (without any protection against dirt), they should damage in a short time.
Bange
I agree, but since it is not jumping and the gap is still acceptable, the exchange will be for later.
The most important thing for the moment was to give a lot of stability to the plate sector, which was rocking... with the screw I put in, it was very firm.
Those should be at least the snap ring version. But the closest metric snap ring bearing is too large. The flange ones are better design. The snag ring or flange keeps the bearings from slipping inside the rim mounting hole.
I use the XIKE version here which are about 4.87 each.
3/4 x 1-3/8 and 1/2 to 7/16 wide.
Gord Baker
I believe that Bolt should have always been there. A Shoulder type bolt on the ones I repaired.
Good photos. I believe those Torrington bearings for king pins would last a long time and even if dirty would assist steering.
Bange
In the B&S/Murray diagram, the screw does not exist.
Maybe on other models...
I don't see how the Torringtons last long as they are open.
It is possible that in light use, like golf turf, they last a little longer.
Bange
StarTech​
Yes, replacing it with an upgrade is the best indication, but this is another world...either they are not available or they are very expensive...I'll take advantage of the fact that I have my hand in the dough and measure it, because I'm not sure of the nothing originality in this tractor.
Gord Baker
Good photos. I believe those Torrington bearings would last a long time and even if dirty would assist steering.
