5 HP CRAFTSMAN edger engine muffler is loud and leaks from crack in middle
Craftsman Garage
  • / 5 HP CRAFTSMAN edger engine muffler is loud and leaks from crack in middle
I have found that Champions seem to give less problems in 2 strokes
So I use NGK's in most 4 strokes & Champions in most 2 strokes unless the customer specifies a particular plug brand
I also stock Bosh plugs as I got a good deal on 400 of them .
champions also seem to have a higher heat range, but get hot quicker on my engine, probably because we are go-kart tuning it so it will be at full throttle a lot of the time when we accelerate :)
Yes
B=14mm thread
P= projected tip
K = reduced hex size
I have some very thin walled plug sockets so I usually don't bother keeping K plugs as they are in the next price group up .
