5 HP CRAFTSMAN edger engine muffler is loud and leaks from crack in middle
Craftsman Garage
  • / 5 HP CRAFTSMAN edger engine muffler is loud and leaks from crack in middle
my 5 HP CRAFTSMAN edger engine has a crack in the muffler and is crazily loud, this has been a problem ever since I got the engine 1 year ago. Is there a way to seal the crack without buying a new muffler? would super glue work or gasket sealer? engine serial code: 100202 0015-01 6811127 craftsman edger model number: 536-83610 Thanks for any help provided.
Incorrect model number for edger.
As super glue work or gasket sealer a steak would work just well and at least you have dinner cooked.
sgkent
buy a new muffler, it is rotted out too. Like $21 max
Craftsman Garage
oof, ok
Now, Now you know a 1968 muffler will be just like a brand new one. :p
Craftsman Garage
thanks scrubcadet10, but those arent the right muffler for it, but I found a replacement
I’ll bet a repair shop in your area has a screw in muffler you could get for about $5 used $10 new. I know I’ve got at least two laying around somewhere.
Scrubcadet10
Moderator
Staff member
Are you sure of the engine Model and Type numbers?
