OK .... New Carb fitted but the problem is still the same :frown: .... I think we are "barking up the wrong tree" any other thoughts what could be causing the random popping?
Also, yesterday I broke the drive belt an in my confusion I switched off the ignition and when the was at full RPM. When it had almost completely stopped there was a HUGE backfire (like a firecracker!) and flame flash on the starter motor side of the engine. Not sure exactly where the flash came from, but most likely the exhaust box :confused2:
Any thoughts gents.
Any thoughts gents.
