Auto Doc's
- Sep 7, 2024
- Threads
- 23
- 1,951
Hi Slomo,
I used that trick years ago when I worked in an automotive shop. We occasionally would have a vehicle that the drain plug would not seal properly on. Applying a vacuum to the filler and then quickly switching the drain plug worked pretty slick.
Not sure how that would work with an oil filter change on a rider engine. Maybe it will draw the excess oil out of the oil filter if left to set for a few minutes.
