Skippydiesel
- Nov 29, 2020
- 523
Hi Grumpy Cat,
Strikes me that efficacy of non return valve will depend on;
"2000 Toyota Avalon filter is mounted 45° down yet most all oil gets sucked out overnight in spite of the anti-drainback valve."
Interesting observations. How do you know? Have you remover filters at, say ,1 minute intervals, to check for retained oil quantity?
In the days before non return valves - on engine start up, you were supposed to wait (before revving/loading the engine) until oil pressure reached a desired level, indicating system full/circulating. In some engines this could take many seconds (especially those with many kilometers/hours) during which bearings/bushes may be running dry.
In modern engine the oil pressure no longer warrants a gauge, all that you get is a warning light, if pressure lost/not achieved. The only time you might see this light, is before engine start and after an oil change. The latter only showing for a brief moment or two, IF the mechanic has done a good job.
My Ford Ranger has a non return valve in the oil circulation system - not in the oil filter (as did my MB, 300D, W123), however all my other engines have the valve in the filter.
- Quality of filter
- Column of oil above/below filter, providing additional sealing pressure (absent when you remove filter & allow to drain on side)
