- May 6, 2010
- 12,048
With the briggs flywheel tool the bottom nut is just used to keep the pull bolts from falling out of the puller. They are never tighten down on the flywheel. Should just thread the bolts through the flywheel enough to capture all the threads. Don't turn into the block or could do damage. After getting a good snug pull with the nuts above the puller, I wlll take a punch and stick through the center hole and then give it a good tap with a hammer to break the flywheel loose.
