- Feb 19, 2020
- Threads
- 123
- 12,912
Star tech you were precisely right that was what it was I think you very much!Using your image, that is a 5/16 bolt.
The 5/16 that is that long used on the mower is the one at the PTO clutch.
Anti-rotation bolt that keeps the clutch from spinning.
Its a belt guide for eng pullyAny idea where this bolt came from. Noticed it in the back yard after mowing and assume it came off my mower but haven’t noticed anything missing. I have a 2021 bad boy maverick
If you take something apart and put it back together enough times, eventually you will have two of them.Any idea where this bolt came from. Noticed it in the back yard after mowing and assume it came off my mower but haven’t noticed anything missing. I have a 2021 bad boy maverick
I do not see anything in the diagram that looks like this bolt. What number of the part you are referring to?Any idea where this bolt came from. Noticed it in the back yard after mowing and assume it came off my mower but haven’t noticed anything missing. I have a 2021 bad boy maverick
My thoughts also. Check your mower deck. You’ll see a empty holeLooks like it may be some kind of belt guide.
