Found a bolt not sure where it goes
Molon labe
Any idea where this bolt came from. Noticed it in the back yard after mowing and assume it came off my mower but haven’t noticed anything missing. I have a 2021 bad boy maverick
7394
Weird that the nut is still on, think that would have prevented it from falling out or off..
Definite wear pattern around the 1-3/8" point from bolt head.
My thought is there are a couple washers and the other nut that holds it on are missing Basically sandwiched to something. Did a search of the parts list for his mower but didn't find anything of that size.
Scrubcadet10
Moderator
Staff member
Looks like it may act as a guide on the back of the deck and it shows 2 nuts being used on it to attach it to the deck shell, one of which probably loosened is laying in your yard somewhere
Molon labe
Ok so I looked and I have those two “guide bolts” that are on the back part of the deck and this bolt is a 1/4” bolt in
