MrLarkins
 - Jun 23, 2023
- Threads
 - 1
 - 20
yes! I can drive it for another few minutes on FULL choke.Okay good. When it goes to die, will giving it a bit of choke help at all?
In the video it sounded like it was either starving for fuel or getting air it shouldn't be getting. Either way it seemed lean to me. But that's just one opinion.yes! in can drive it for another few minutes on FULL choke.
Carb spray. When it starts acting up, carefully spray the seam and the ends at the head.It is plastic. How can I test your theory?
I've attached some images of the manifold. the seem and top dead center...take a close look.
ok, done. ran it, and when it started to die, I sprayed the seams...no effect. I then sprayed some carb cleaner directly into the air box, and the engine picked right up and rev'd, for a moment anyway. Should I take apart the carb again and take a closer look?Carb spray. When it starts acting up, carefully spray the seam and the ends at the head.
This is text book floating debris in the fuel tank blocking off the fuel supplyyes! I can drive it for another few minutes on FULL choke.
how will the fuel filter affect this attempt?This is text book floating debris in the fuel tank blocking off the fuel supply
Next time it stops pull the fuel line off on the tank side of the pump ( if fitted ) and blow back through the fuel line.
If the engine fires right up them either the tank needs a clean or the fuel line has degraded & needs replacing .
I just makes it harder for you to blow back.how will the fuel filter affect this attempt?
yea, but it won't lastOnce it gets bad enough that it dies, will it start right back up?
