gregjo1948
- Nov 28, 2012
- 393
Sounds like there may be a collapsing fuel line or something in the gas tank blocking the fuel port, causing it to starve for fuel.
I was thinking the same thing when i watched the video.And this. Once you get the engine bolted to the frame, check to make sure your engine has an adequate fuel supply. Check for loose debris in the tank, check to make sure the fuel pump is good and check for pinched off fuel lines. You have an obvious fuel starvation problem. I've read thru the thread and if you've made sure the carb is not the issue by cleaning all fuel passages then the issue is going to be a fuel supply problem.
BTW, the engine video of the one side overheated was caused by running the engine for an extended period without the fan shroud/blower housing. Any air cooled engine will overheat without that shroud/housing in place.
Worth checking the exhaust isn't blocked, easiest way is to remove it and try with ear defenders on.First time poster here, thanks in advance.
I'm running a Husqvarna RZ5426 with a Kohler SV735 (Courage 26hp 725cc). I purchased it new years ago and have maintained it well. This season something has changed. Let me describe the symptoms and tell you what I've looked at already.
Symptoms:
What I've looked into:
- Runs a slight bit rougher than normally. By this, I mean that the engine shakes more than years past, but it isn't much.
- Starts fine and runs for a good 15 mins; Then the engine will wain when under a strain, to the point where it dies. This can be mitigated somewhat by disengaging the blades and releasing the handles so that it idles in neutral.
- If the engines does shut off, it can easily be restarted, but runs best if let set to cool down.
The only defect I did find was a crack in the muffler.
- I've checked the oil level; it is full but not overfull. Oil is clean from a recent change.
- There is no smoke in the oil fill pipe as would be the case if a head gasket was leaky.
- The carb was taken off, apart and cleaned. No trash was in it.
- Gas is fresh, and fuel filter was replaced last year. Fuel pump was tested and is pumping as it should.
- Air filter is new for the season and not clogged.
- Battery is 1 year old and holds at 12.8v.
- Spark plugs have spark. I did disconnect each spark plug momentarily to see if each cylinder was firing. I did this quickly so the engine wouldn't run too long...just a couple of seconds. Each cylinder ran fine.
- I cleaned the debris was the engine block fins, thinking it was a cooling issue. one side seems clogged with grass, but there was no oil leaks anywhere on the block, and I looked hard after taking covers off.
Okay, there it is. Any suggestions of what I should look into next?
Banana in the tail pipe?Worth checking the exhaust isn't blocked, easiest way is to remove it and try with ear defenders on.
