- Feb 19, 2020
- Threads
- 114
- 12,427
Got to be carefully on chains. As it depends what bar specs are. Oregon and Sabre chains are around $30 retail for this saw. Just be thankful that you are not wanting a carbide tipped chain. They are about 5X the price or more. I paid $140 cost for a 18" 3/8lp chain about 6 yrs ago.16 inch chain is $36.95
There is pitch, gauge, tooth style, and DL count. Also the Stihl bar is most likely shorter than labeled. Several I installed were nearly an inch shorter what they claimed if you measure as they show how to measure them.
But anyways the 16" MS271 appears to use the .325 .063 67DL BNC setup which can be either semi chisel or chisel tooth. Then of there is a safety version or Pro version. There is also a few other options but they are not common. Like ripping vs crosscut chains.
