shadetree#1
- Oct 31, 2022
- 153
Here is couple of pictures of the regulator and how to test and a picture of where it might be located on your engine. If it's not located in this area just look for the regulator that has the 3 wires attached. Yours might be different. If we had the model of your Kohler engine we can tell you where it is or send you a picture. (or you can search on-line using the Kohler engine Model #'s.
Some of them Kohler regulator wiring plugs do not unplug from the regulator easily.
Kohler voltage regulator - - Video Search Results (yahoo.com)
https://www.ebay.com/itm/3844072389...fQr/8+qgtSETdCqmzYrhGLog==|tkp:Bk9SR8bxxfuMYQ
