JoeFromRomeo
- Nov 8, 2022
- 16
I've got a Cub Cadet XT1 LT1 - purchased at Home Depot. It's been a great mower up until now. It won't start or crank - and keeps blowing the 20 Amp fuse that is inline with the starter solenoid. I can jump the starter with a cable from the positive to the starter -- and it will crank then. I replaced the starter solenoid - and it's still doing it. Any help is greatly appreciiated. I haven't done anything with the wiring harness (no add on lights or horns).... I can't find any bare wires rubbing against the frame ... Any help is appreciated.
SOLVED!!!!
- The problem as a dead short in the headlight wiring.
- Someone said - start unplugging the various circuits - and see if the fuse blows.
- I Unplugged the front head lights - and could start the engine!
- As it turns out the wires had gotten pulled, and bare sections of wire were contacting one another resulting in a Dead Short.
Model #: 13AOA1CS056
Serial #: 18108H40302
Engine:
Kohler 5400 Series
18 HP /541 cc
KS540
SPEC PS-KS540-3011
MOdel KS540-3011
SOLVED!!!!
Engine:
Kohler 5400 Series
18 HP /541 cc
KS540
SPEC PS-KS540-3011
MOdel KS540-3011
