- Feb 19, 2020
- Threads
- 79
- 10,271
My lord this is an AYP/Husqvarna mower. Stanley B and D might have brought the name Craftsman but Husqvarna still provides the parts for this particular. Just got to have a good database that is update with the supersedes of the part numbers. Stanley B and D actually brought out MTD which is what OEM Craftsman was using on their last rider mowers.
Bert if you are looking at the Searspartsdirect site. A lot of the times they will list things NLA just because they have never updated their part numbers.
PN 193414 has been superseded a couple times. > 532193414 and 531148901 is the service kit.
PN 169022 has been superseded to 532169022
PN 532173442 has been supersede > 532141043 > 531165901
Even the following website which you can get the original part numbers which I still need to run through my database to get the current part numbers but the Sears site don't list have all the part numbers listed or at least they didn't this morning. They also list the parts as NLA but that is just because they don't have access to the Husqvarna parts.
https://www.partselect.com/Models/917275350/
And two problems I see is both the LH and RH belt guard (retainers) are too far from the spindle pulleys allowing the belt to fall off. And the current belt part is 532193214 superseded from 193214. These needs to less half of the belt thickness to keep the belts on.
