Loose belt issue. Craftsman lt1000 model: 917275350
OJSANDOVAL
  • / Loose belt issue. Craftsman lt1000 model: 917275350
That is normal when the deck is disengaged.
I was wondering if there supposed to be 2 of those belt keepers though is what I was asking. I only have one on the right side and none on the left side. That’s also the side the belt keeps getting stuck under pully
Just the one. And then the belt is a little too long. I would try one that is about 1/2 inch shorter as the spindle pulleys vee groove is probably worn quite a bit. something like an 1/2 x 90"
OJSANDOVAL
This one that I have is thre recommend replacement part it’s 1/2 x 90”. So is there like a 1/2 x 85” I should try?
Scrubcadet10
Moderator
Staff member
an 85" would be far too short.
i'd try a 1/2x89 or 1/2x89.5"
OJSANDOVAL
Since it won’t be the craftsman OEM replacement part do I just buy any generic 1/2 x 89” belt? Like any one off Amazon or does it still need to be for a craftsman specifically?
Scrubcadet10
Moderator
Staff member
generic will do, as long as it's the correct dimensions.
quality and durability may vary.
Cusser
I only have a belt keeper on the engine on the left side. There is not one on the right side. Is that normal to have one an not the other? The right side is also the side that it keeps slipping under the pulley into could that be the problem right there ?
My own 2005 LT1000 is a 917.275371; yes it is confusing that different manufacturers made these all under the Craftsman name.
Anyway, mine does have a "belt keeper" on both sides. My main issue has been dirt obstructing the movement of the tensioner pulley, or a broken spring for one of the keepers.
MParr
247 prefix in model number = MTD made Craftsman.
917 prefix in model number = AYP/Husqvarna made Craftsman.
All current Craftsman mowers are Black and Decker/MTD
Prime Line, Rotary, Oregon & Stens all do OEM spec ( so they say ) mower belts
All of them have a "belts by length" table on their on line catelogues.
Stens & Prime Line also do a line of strait Kevlar reinforced belts in 1" increments .
Gates do a line of mower belts and again have a belts by length feature in their catalogue
Now there is a massive difference in belt structure
Deck belts usually have bigger reinforcing cords in them to give them greater shock loading resistance
Drive belts usually have thinner reinforcing
Belts that bend backwards a lot have the cords deeper into the V than belts that are not as serpentine in their run
Belts that clutch & need to slip like your deck belt must be covered so they can slip and not be sticky when hot like your cars fan belt
The cover can be kevlar fibre on the top shelf belts , cotton on lower grade & polly propolyene on the cheaper ones .
And then we get to the actual chemistry of the rubber which varies greatly
Finally there is construction
Top shelf belts , like the Gates ones the reinforcing is one thread wrapped spirally so there is no weak point in the belt
Cheaper belts are simply cut from a long roll & joined together then wrapped
While paying a lot does not guarantee a top quality belt paying a little guarantees a low quality belt
The only belts I fit come from my wholesalers and are Gates, Rotary, Stens , Prime Line or Oregon .
In 11 years of mower repairs I have never had a premature belt failure with any of them that was not my fault due to improper mounting .
  • Like
Reactions: CDE
