- Sep 24, 2017
- Threads
- 288
- 6,901
Toro.com or your local Toro dealerI have a question. Where would be a good place to go to ask about a Toro horse tiller? I have a 8 hp and I don't have a manual. Many thanks
Thank you,Toro.com or your local Toro dealer
I would love to have time to watch such a thing but I just don't have the time. Someone with less to do might enjoy it. Now back to more important things.
Get yourself a can of freeze sprayOk update time. It finally stopped raining enough here for me to get the Murry out and test it out. After about a 10 min ride I stopped for a bit. Went to start it and the same thing no start. After about 20 min it started right up. Oh well!!!
Ok I'm back to square one but I'm not giving up as it's running better than it ever has. Hell it might be fixing to blow up.. LOL
Now that's a thought I haven't thought of and that makes a lot of sense. Thank you so much for your help.Get yourself a can of freeze spray
Most electronics stores keep it for testing circuit boards with.
When the engine is hot, spray the magneto magnet in the flywheel with the freeze spray till it is at room temprature.
Magnets loose magnetism as they get hotter
As this is a quite old engine it just might be that the magnets have weakened to the "marginal state" where at the slow cranking speeds they just can not produce a spark when hot
