troy-built
- Sep 15, 2020
- 6
- 120
LOL There is none. Remember I said I pulled the motor to replace the pan gasket. It's clean as a whistle.Yipee!! She's a runner.
Okay, that filthy engine is next. Remove the engine shroud again and clean all that oily dirt mud pack muck off the top of the engine block and cooling fins.
Man was I wrong, You have a good eye. I totally missed that dirt until you mentioned it and then I seen it in the pic. That's why I like taking pics when I'm working on something because I couldn't see down in there because it was dark and I took the pic with the flash on. The dirt was only in that one spot and I'd be willing to bet that little bit of stopped up fins was making that head get hot under the coil.
This is exactly why I like people chiming in on a forum.
Many thanks
