I have a 2016 DC Silver Eagle and the left side is weak compared to the right side. I have adjusted everything as best I can but can't tell if it is the Wheel Motor or the Pump. Has anyone ever tried swapping the wheel motors for testing?
There should be. Use to give a break down of the wheel motor but since they switch to parker the don't seem to have anymore.Is there a tag or number on the wheel motor so I can see if I can get a seal kit ? I have a seal kit for the pump.
It operates smooth, just doesn't have the same power/speed the right side has. I have adjusted everything but I do have a new belt. i will try that next.Is your belt tight this can cause this problem. Tighten the nut on the spring bolt to were the spring is compressed to 3 inches. Also the idler arm should run parallel to the frame. If the belt has been loose and slipping it could wear the belt down and bottom out in the pulley then a tight belt won't pull. You might replace the belt and adjust according to what I stated. You can slide the engine to get the proper adjustments. Then you would need to readjust the engine to deck belt. Compress spring to 3 inches like the drive belt. Does the wheel motor feel kinda jerky when you push hard on the steering lever kinda like a quiver.
