- May 6, 2010
- 12,057
There could be a short in the wiring but could also be a clutch that is shorting out only when hot under certain circumstances. If you don't want to purchase the clutch outright. Replace the switch and the main fuse, but also tap into the power wire to the clutch and install a 7.5 amp fuse holder as discussed before. The run it. If the fuse blows then the clutch is bad and that small of fuse should protect the switch.Let me some up. Just want to get you the right info.this is now the 3rd time that both the switch and fuse went out at the same time. So do you think the Clutch is the problem or something else going on? I hate to buy the clutch if it is not bad. You think I might have a short somewhere if not the clutch?
Worked on a Scag for a commercial customer years ago that would blow the main fuse after running like an hour, which would also kill the engine. Customer would replace the fuse and get the mower started and continue with his mowing until it blew again. I ended up installing a 7.5 amp fuse in the wire to the clutch and that way it would only blow that fuse and not shut the mower down. After a couple times of it happening we were sure it was a bad clutch, but only would fail when hot. So over a weekend when he wasn't trying to use it he let me have it and I mowed my yard with it. I tested the resistance of the clutch when cold and got something like 3.1 ohms. After it blew the fuse I immediately checked the resistance on the clutch at it was .3 ohms so would only short when hot.
