Good luck, the dry lube didn’t do so well for me. Graphite powder was MUCH better than Teflon spray. Teflon spray was really bad. So far the bearing conversion is still doing awesome on mine. Zero maintenance and better than new. Only about 10 mows so far, but before it was going down hill by 3 or 4.
Well it worked better than before using the dry lube but still had a few stuck pull backs. I guess the only thing one can do is grind down that axle. I did do a little sanding on the axle but I guess not enough.
